Building windows
"Rebate down the back of the pulley stile for the wag tail" ? It has to hang free for you to instal the weights.
About 22mm for the stiles would be about right. I'd go for 32mm thick stiles on a spiral balance sash. You want to cut a slit in the head for the wag tails. Then slip the wag tail in loose, with a nail half way thru the wag tail, then it just hangs off the head. As its just been said, you need a loose wag tail to install the weights. On a double box sash, the stile cover can be trenched in between the head and cill, but the two wag tails still need to be loose.
Thanks Agbagb and Joiner_Sim what you say makes perfect sense and that is what I will do.
Because the lead weights are going to be big due to the weight of the glazing units I had thought about having just one large pocket on each stile to access both weights each side, would that be normal practice?
One pocket per side is the norm, in the bottom sash side of the pulley stile, only way I've ever seen.
Top sash goes in first, pull the wagtail over and fit the weight, then let the wagtail hang for fitting the bottom sash weight.
Check out the geometory of the pocket length to ensure the weights can be fitted in. If your lead weights have a through hole you can cut them in half so they are articulated when threaded on the cord. By doing this you can have a smaller pocket.
You can see the pocket size I ended up with here http://slidingsash.blogspot.com/2009/01/fitting-sashes.html
Very tidy work. Personally I'd just buy the windows, but I'm sure you'll end up with a better end product this way.
Ed
I decided to cut large pockets in each pulley stile so access to the weights will not be a problem.
The pocket covers were cut to be a snug fit and planed flush
The rebate for the parting bead channel was routed out. Because the pocket hole is cut wider than normal the parting bead will help to hold it in place and I am able to insert two screws which will be concealed behind the channel
I have also cut the mortises for the pulleys
The hardware and weights have also been delivered this week from Mighton Products (thanks for the tip)
I got to spend a bit of time in the workshop today and started to assemble the first of four sash boxes. I also primed the first cill with aluminium oxide primer.
Painting is my least favourite job, Im thinking of one coat of primer (maybe two on the cills), two under coats and one top coat. Any comments/advice would be welcome.
I like the way you have cut the pocket and concealed the screws. I just hope that such a large pocket does not weaken the stile.
Am I right in thinking that you are painting all the lovely hardwood!?!?! It will last for ages, but if I was doing it as a painted finished, I really wouldn't have bothered with some of the things you have done. i.e. mortice and tennoning fascia boards...
Hello Joiner_Sim, The pockets look a bit bigger on that picture than they are because of the angle I took the picture at but the stiles are, as commented on before, thicker than would be considered normal. That coupled with the haunched joint to the outer and inner linings make for a very strong frame.
The boxes and sashes will have a paint finish. The choice of timber and construction method is an effort to make them long lasting, I also enjoy the process of hand jointing. I understand in a commercial shop this would not be appropriate but if I was trying to make a living from my workshop Ive no doubt I would be very hungry by now :lol:
Have a think through the final assembly. Will you have to fit the parting bead after both sashes have been fitted? It could get a bit tricky.
The build is looking good
Andy
Its a good point Agbagb and one which I did consider. I will have to fit the parting bead once both sashes are hung but I think with the staff bead yet to be installed I will be able to swing the lower sash inwards slightly to give me access to the parting bead channel.
I notice from your blog that you fixed the frame in with just four screws, one in each corner, did that work out ok?
Joiner_Sim can I ask how you normally fix your frames in?
Thanks John
I'm interested to know how others fix the frames in as well.
The four screw have worked on mine but it wasn't exactly slick (more of bodge). It's something I didn't put much thought to. By the time I'd ripped the old window out there wasn't much time left for thinking.
Glad you got the final assembly thought through.
I have been following this with interest. I like the substantial design of the box.
It is not clear to me how you are fitting the parting slip/wagtail. Given the wide pocket you have cut, could you have a fixed parting slip which would seem superior to the usual flappy one that in my experience can cause some problems (thinking that square weights might be more prone to fouling)?
cheers
Hello Scholar, My intension originally was to have a fixed parting slip/wagtail. Following advice on here I have decided to have a loose wagtail as even with a wide pocket it will be usefull to be able to push to wagtail to one side. As has been pointed out it is normal to slot the frame head and hang the wagtail with a nail or pin but I will have to use a different method as I cut short the frame head, as can be seen here...
I will make up something to hang the wagtail from.
I spent some time today correcting a mistake I made yesterday. I decided as Im building so many windows that I should invest in some more tools... so I bought one of these
Normally I build furniture and generally sand by hand so I have never owned a power sander. Keen to try it out I decided to sand the first assembled frame prior to priming. In a matter of seconds I managed to ruin one of the frame edges by being careless and much to aggressive, so this morning has been spent routing a rebate along the edge and scribing in a new piece
The new piece glued and clamped. Normally I would use clamping blocks but the clamps were just big enough to span the frame
I do wish I knew what you guys were all on about. This is a side of woodworking about which I know absolutely nothing. I've made casement windows before now, but never a box sash. Can you point to a good primer on the subject, please?
Steve
Welcome to the ferociously effective world of the Rotex.
For finish sanding, you want to hit the button and use it in RO kitten mode.
Not that you haven't worked that out already the hard way!
Hello Steve, Im not sure I can, Im learning as I go. The only reference I have used apart from advice on here is a book called Carpentry and Joinery by Brian Porter, which bit has confused you?
Hello Jake, yes it is a very effective tool and one which Im going to have to practice a bit with I think
Well I don't know what a wagtail is, for a start.
But also I don't understand how you make box sash windows draught-proof. We had them in our Victorian semi when we were kids and all I remember is them being blooming draughty and being sealed up with sellotape.
I suppose I just need to do some trad reading.
Steve
