1steven
Claremorris Ireland
Is that cement as mortar or lime?
mortarIs that cement as mortar or lime?
Thanks so much for your input.The width of the building internally is about 3.7m, and around 5m in length - so losing 350mm is probably fine.My 2p worth, which I think is what others have suggested (I think your original idea) is to build a building within the building isolated from the structure. I think you are on a loosing battle trying to remedy the damp issue, gutters would help but at what cost and to what level of benefit. You'd loose the lovely aesthetics but the only way to keep those would be a full on renovation £££££, which seems a poor choice as it is not your building you are investing into.
One of the positives of building a structure inside is that you have a good weather screen so you're not really worried about managing water ingress from rain etc. So for example you could look out for a large second-hand double glazed window (free on gumtree) and use it as a skylight facing the transparent roof panel.
You would loose some space internally as I think you would want to leave a good gap at the rear between the damp wall and the new structure, so that the old wall still has reasonable ventilation to/from the roof void. With a 100mm gap and a 100mm stud wall at rear and a 50mmg gap and 100stud wall at front, you've just lost 350mm from the width of the room, is that manageable?
Messing about in sketch-up, some of the things that jump out at me are:
- is the space big enough to enter through the normal door and then have another door on the internal structure.
- do you need access internally to the doorway to the room on the right, it looks like there is another door, so perhaps not.
- you risk creating a fantastic home for wildlife, under or between the internal walls, i was warned of this when I put insulation quilt in the floor of my shed, fingers crossed so far i've been ok, but im urban not rural.
- if you uses screws for construction, you can dismantle and take with you, some cladding on the outside and you have a shed.
- a 4x2 floor with lots of feet to limit span width and hence timber height, dpm under the 'feet' to stop damp ingress into the timbers.
- I would cross batten the internal roof structure for insulation and space for a reclaimed window
- simple 4x2 frame with PIR insulation in floor, walls, and ceiling. Internally clad in your choice, 9mm ply or 11mm osb
- i'd not bother with external building wrap as there should be no water to worry about
- with this approach the cold side of the isulation is very well ventilated to no worry about condensation either
- you may want a couple of LED panels in there the design would reduce the incoming light from the panel
- i think you're looking at c.£2k for materials
Some thoughts, perhaps helpful perhaps not.
Good point - no need to get on top of the box - so would 2x2 for the wall framing work?£2k seemed quite cheap to me.
But since the workshop will be inside and not subject to the wind and snow could the walls and roof use smaller timbers than 2 by 4? Will you need to get on the top of the workshop.
I have seen many offices in box type constructions inside factories and warehouses, nothing odd.
I'd make the inner room 3.6m X 2.4m if at all possible.Thanks so much for your input.The width of the building internally is about 3.7m, and around 5m in length - so losing 350mm is probably fine.
I think there is room for an internal door - however, I do need internal access to the far room. So there will need to be 2 doors.
£2k in materials "yikes" ..... !
Why 3.6m by 2.4m that's a lot smaller than nit could be.I'd make the inner room 3.6m X 2.4m if at all possible.
50mm cavity will be fine.
3x2 will be fine ( and better if you want to use later on) with a 50mm pir / polystyrene insulation building fabric to outside and osb to inside.
I was thinking 4 x2 for framing around doors, corners, windows, where you are going to hang shelves, roof plate and 4 by 1.5 other places in roof and walls.Good point - no need to get on top of the box - so would 2x2 for the wall framing work?
Where would the bulk of the costs be - in the wood?
I estimated about 70m2 of wall, floor and ceiling area. At £40 per 100mm insulation board that £900 of insulation. About £600 for osb and £500 for studs, fixings etc.Thanks so much for your input.The width of the building internally is about 3.7m, and around 5m in length - so losing 350mm is probably fine.
Just be aware 4x2 is larger than 4x1.5I was thinking 4 x2 for framing around doors, corners, windows, where you are going to hang shelves, roof plate and 4 by 1.5 other places in roof and walls.
Sorry I meant 3.6 wide X however long and 2.4 high if possible!Why 3.6m by 2.4m that's a lot smaller than nit could be.
Ah... that makes sense. I think I can make it 3.6m wide, and 4.8 long. 2.4 high won't work though. In the words of the late great Meatloaf "2 out of 3 aint bad"!!Sorry I meant 3.6 wide X however long and 2.4 high if possible!
