A valid pointIndeed. If you're selling these, I guess it won't hurt to include a disclaimer that you shouldn't look directly at the LED though.
When it's installed, you really have to try hard to look into it, but you have to assemble it and will almost certainly test to see if it works, and may inadvertently stare into it. However the OP is just using an already available commercial product.>the hazard from very bright LEDS remains the same.
Yes, absolutely. High power LEDs should not be considered safe to look at directly.
I assume you'd have to be fairly acrobatic to be able to stare directly at this once installed in the saw though?
If you are just using the standard supply from the saw, that will limit the output. Just do some tests to check the temp of the metal enclosure when the unit is running all closed up. Can the lamp be left on? run it for a few hours at a known ambient, then see what temperature the metal enclosure reaches. You will then be able to see what headroom you have for the plastic, for example if the lamp reached 60C at an ambient of 20C, you have roughly 25C headroom.My Dewalt is a class 2 as well but it is a good 5 years old now. The LED i'm using certainly seems powerful enough, heat might become an issue if you go too high with power output. The Aluminium casing on this one should help disapate a lot of the heat too, its designed as a cabinet light after all. The PETG plastic I use has a heat tolerance of around 85° at continuous use, it prints at around 240°.
I have the complexion of an albino vampire, so NE Scotland suits me fine, be nice if it didnt rain quite so much though...
No the saw itself provides the power for the light/laserI brought one of these shadow lines for my Bosch glide and it transforms the saws ability to cut to a line. The laser it comes with gives two lines and your cut is between them but not clear, with the shadow of the actual blades teeth it is just so easy to cut to a line.
@Westy619 Although I brought and fitted one I did not pay much attention to the design, is it a combined LED with a built in PSU ?
But in my case that would be 110 volts or are you saying the saw provides a lower voltage for the laser / shadow line unit ?No the saw itself provides the power for the light/laser
Correct, there is a small DC PSU inbuilt within the sawBut in my case that would be 110 volts or are you saying the saw provides a lower voltage for the laser / shadow line unit ?
