BS250 >> metal cutting
GrahamRounce
UKW Supporter
26 Jul 2007
Bethnal Green
Hi all - I have a Record Power BS250 which has served me well for wood and aluminium.
I'm now more & more wishing that it would cut mild steel, say up to 6mm thick.
There are plenty of VFD speed controllers for synchronous (= induction?) motors, but they all output 3 phases, I don't know why. Can I just use one of the phases? Would the wattage then be only a third?
Apart from doing rebuilding to allow various belt arrangements, has anyone else managed it successfully somehow else?
Thanks v much,
The problem is that a wood saw is just far too fast, you need to aim for a blade speed somewhere in the region of 200 ft/min for steel, so typically around 1/10 of the speed it normally runs at.
I was in a similar position using a Kity with a metal cutting blade. I was able to change pulleys to get it to run at about 1/3 speed, but still much too fast really.
I ended up converting a little Clark CBS 190 by replacing the motor with a 12v 350w one intended for an electric bike. It has a built in 9:1 reduction gearbox, together with a variable speed control. I had to make a new gearbox output shaft to suit, but got the motor from a local guy who repairs electric bikes. The screw on the end of the shaft that holds the sprocket was knackered so scrap as far as he was concerned, and so free!
As I was going to replace the shaft anyway it didn't matter to me. I paid about 15 quid for the saw on e bay. I already had some big mains to 12v DC power supplies so the only other thing I had to buy was the speed controller, which was less than £10.
I put the power supply and electronics in a project box on the back and the speed controller has a pot and LCD, which fits neatly in the space previously occupied by the on off switch.
Very small, and not a great quality machine, but works a treat for cutting the various steel and brass plates I use for repairing clocks. It will happily cut up to about 5-6mm steel and 12mm aluminium using tuffsaw bimetal blades.
So as an "I wonder if" type project I am quite pleased with it, and so is my Kity !
The other issue is that if your machine uses rubber tyres then metal will get embedded in them, and very difficult to get rid of, and may then get into any wood you cut with it subsequently.
My Kity is an old 612 and doesn't have tyres.
Doing it today, one of these might be a good candidate to replace the existing motor:
https://vi.aliexpress.com/item/1005007683855333.html
That is the first one I found; they are available at lower prices and on Amazon.
Maybe have a think about the format in which the steel you wish to cut arrives in your workshop. That will tell you what percentage of required cuts can be made on your existing bandsaw
If the steel is similar to a sheet of plywood, a variable speed jigsaw (run along a straight edge guide) and good blade could be an option.
Another option is to mount the jigsaw upside down, in a table, with a guide for the top of the blade. That allows you to use a fence.
On a vertical bandsaw, cutting a 24" length off a 3m long stick of material will not be easy. For that, an angle grinder and 1mm slitting disk is good (and can be done outside - take the tool to the work).
A vfd will not do this.
If you did buy a single to single phase vfd (there is one, it will cost £ a few hundred) when you dial your machine down to the 1/10 speed that you need from @Fergie 307 and others' experience, your bandsaw motor which only outputs 200W at full power will now only be outputting 20W.
It will barely scatch the metal and stall if you look at it harshly.
A VFD isn't a gearbox.
Portable bandsaw (these are geared for metal cutting), variable speed jigsaw with a metal cutting blade or a special "cold saw" - a circular saw with low speed high torque motor/gearbox.
And remember the feel of a hacksaw blade if you twist it in the cut, these are straight line cutting solutions, not for curves, except maybe the very shallowest.
A 3ph VFD on 1ph motor would just trip with a phase loss fault.
You can get VFDs for 1ph, but most 1ph induction motors have a start circuit that is switched out above 70% or so of rated speed. Running them below this will likely burn out the start winding and switch, or blow the cap.
You’re better off with mechanical speed reduction here. Taperlock pulleys are very handy for this.
The discs sold for stainless steel are very good and last longer than other types.
Thanks!
I'll look at that Clarke thing. "Very small" isn't necessarily a disadvantage!
And that servo motor, too.
Surely with a VFD the power is the same regardless of the speed. It's still the mains voltage, after all, just a different frequency?
I have and do use a jigsaw, but it's noisy and of course vibrates a lot. Actually, that's what I'm trying to get away from, sorry!
I should have said that at the moment what I'm trying to do is, starting with a 50mm x 6mm x 1m mild steel bar, making a dozen or so 3-pronged things like tuning forks, about 40mm long, and each square prong and each space 30x6x6mm. Jigsaw works, but is slow, and needs a painful amount of filing!
(I'm also looking at casting, but that's a lot of bother! Forget I said it!)
Thanks all, again,
Do you have a sketch of the plan view of the item?
The fastest way to remove metal might be a twist drill - especially if the top of the prong can be semi-circular.
Having read what you describe, a cold-cutting metal saw (Evolution Rage 4 is a popular one) might work well. As you are making multiples of the same thing, making a jig (flag stop) to position the work optimally will be worth the effort.
Instead of working with 40mm long items cut one at a time from the big bar, it might be possible to make a double-ended part out of 80+mm long and then cut in half at the end.
With the chopsaw above, you can gang pieces of the parent stock together (it should cut 3 at a time), chopping off 40mm increments. That alone doubles, triples or quadruples your throughput.
Look at water jet cutting - if you can make a vector graphic like an SVG there’s a few places that’ll cut and ship to your door. If you’re doing enough to warrant investing in a saw may work out better to just outsource.
No. Absolutely not.
Skipping a load of details, a VFD basically maintains a constant ratio between frequency and voltage at it's output.
If it didn't reduce voltage as it reduced frequency to slow the motor down, any motor would overheat and burn out.
The result is that power is essentially proportional to frequency / speed.
As you slow the speed down, the power is reduced.
So at 10% speed you have about 10% power. Near useless.
As I said, a VFD is not a gearbox.
My Kity is the type with the motor next to the saw. The belt arrangement on these doesn't lend itself well to modifying it to run much slower.
However they did do a version with an integral stand, where the motor sits underneath. This type is actually far more common than the one I have. These are ideally suited as there is plenty of room for the large pulley you would need on the wheel.
Not a great picture, but you get the idea. You can pick these up for around £80-100. 612 and 613 are very similar.
Modifying it would be pretty easy.
If you think a bandsaw would do the job then this is potentially a cheap solution.
    1.9 MB
