filsgreen
Decided to put the sheet of 8 x 4 Cherry veneered MDF to use today by making a bookcase. I had it cut to 4 x 4 x 2 and to minimise wastage I made it 48" high 24" wide. The sides would be 8" and the shelves a little over 7". It would mainly be used for paperbacks.
Here is the base and first shelf routed.
This was the first time I had used my DW 625, I was made up with the power. No problem routing out 10mm deep with a 13mm Wealdon cutter. Spot the little mistake? The only trouble with the router was dust extraction. I linked it to a earlex vac but there was still tons of dust
I had this going full blast.
Once all the shelf recesses were done I sanded with 240 grit
I then routed a rebate to accept a 6mm plywood back for the bookcase.
Time to make the shelves.
Pieces ready to assemble.
Assembling it was hard as the work bench was 24" wide, the same as the bookcase. Not much room for manoeuvre.
Finally got it all clamped up, not without a struggle though!
So that was where I got to at 16:30, just as Pick of the Pops was ending. I have made a design fault in that I never left a space at the base of the bookcase for a decorative stringer. To overcome this I am going to put a hardwood base on it. The veneer is going to be Utile, would it better if I made the base and the veneer out of Ash? Any comments would be appreciated.
Phil
Phil
