Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
Thanks to everyone who replied.
I went to have a look at the Makitas (4350/4351) last Tuesday, the local stockist being closest and with easy parking.
Both the handled and the body-grip ones are nicely made, but I came to the conclusion they are probably too hefty for my immediate needs, although jolly nice. The shop also has Bosch, and apart from the lack of an LED worklight, there was little to choose between them. I've struggled to find a Metabo stockist locally, but one of the annoyances is that both Makita and Metabo expect you to pay extra for a "Systainer" type of case (this is daft, as they supply blown moulded cases anyway, as standard). Bosch are just ridiculous in trying to be different to everyone else. Their system is just a confounded nuisance!
I am heartily fed up with blown-moulded cases because of the waste of space, the time wasted trying to get everything back in again after a job (it's almost always the cable!), and the fact there's usually no room for accessories (e.g. SDS bits on my drill case, and dust extraction adapters, etc. in the biscuit joiner's one).
But I digress, as usual. I've actually decided to go a quite different route. I've ordered one of these:
It uses Bosch's 10.8V Lithium-ion battery system. It's small, lightweight, probably more comfortable to hold, and dead handy for the main task, which is trimming 6mm ply for flooring, and it takes standard blades. It is a compromise, and I will need the bigger (4AH) battery for it if I use it for long periods, but it will go in with the other 10.8V tools, and there's less to lug about as a consequence.
It arrives later today, so I get to play with it over the week-end. I also got a selection of different blades, in the expectation that one or two designs will work much better than others for different jobs.
I feel a bit guilty about the change of tack, but I've learned a lot from the replies (not least that proper jigsaws all seem to use the same blade fitting!), and it's all been very helpful.
Thanks all.
E.
PS: I have the multi-tool in the same series. That benefited a lot from being carefully stripped down and having its oscillating gearbox well greased (it now runs cooler, more quietly, and, predictably, battery life is quite a bit better). I'll be checking the jigsaw to see if the mechanics get warm - a sign of insufficient lubrication. I suspect many manufacturers only use the bare minimum of grease, as you can't sell more tools if the old ones won't wear out!
PPS: Much as I like the system, it seems like Bosch's marketing department are starting to take the p*ss out of the ignorant. They now sell batteries that "go up to eleven" (er 12V, apparently), although the chemistry, and thus the battery behaviour, is identical to the 10.8V batteries (that they actually are).
The individual cells are 3.6V each and there are three of them per battery, in EVERY manufacturer's batteries. The sum isn't a hard one.
Milwaukee (probably amongst others) started this stupid trend by calling their 10.8V systems 12V (most probably using battery systems from the same factory as other manufacturers!). Now Bosch think this is a good idea, and have starting using new labelling saying "12V." At the same time, some of their batteries have almost doubled in price. Of course there is probably no connection between the two things... but I'll put my teacher's mortar board on for a moment:
'BOSCH ! PAY ATTENTION !
'THIS STUPIDITY DOES NOT IMPRESS ME AND HAS BEEN DULY NOTED.
'WRITE OUT 100 TIMES, "I CANNOT 'RE-BRAND' BASIC ELECTRO-CHEMISTRY TO BE A DIFFERENT VOLTAGE."
'THEN GO AND SIT AT THE BACK OF THE CLASS, UNTIL YOU ARE READY TO BEHAVE PROPERLY.'
Thanks all.
E.
