pidgeonpost
Those of you who read my previous post on this may have noticed the comment from 'dedee' that maybe the top was starting to bow. They were right, and how! It was fine according to a long straightedge when fitted too.
Not only has it started to curl from front to back, but is starting to develop a bend along its length. Clearly this is not mahogany as I thought, but banana wood.
This timber had originally been kilned, then stored in my garage (dry but unheated) for over 10 years, and was in the workshop for a week or so before use (I know that's not long, but I thought it would probably be pretty stable after 10 years).
The stock was around 1.25" sawn, which I took down to around 0.75" as it did have a slight twist in it. I guess at least some of the problem may be down to the release of stresses within the timber.
Question now is what to do about it. I do have enough stock left to make another top, but then I risk the same thing happening (though maybe I could reduce the risk by using M+T cleats on the ends - but you know what timber is like - if it wants to move it will do so one way ot t'other!).
Or maybe a slab of MDF painted reddish brown.
I'll post a photo if 'er indoors will release me from the decorating for a bit.
