Blade tightening!!!
martinka":uivz590r said:
stevebuk":uivz590r said:
Ohhhhh that's a good idea Martin , may ask frank about that, I need a couple of screws making Martin and a certain length bar for the delta, you up for the challenge ..
Yeah, no problem, Steve. PM or email me with details.
but i insist on paying this time, thats the deal..
This problem is due to the oil that all blades receive to prevent rust. If you clean the ends
of the blades and the clamp with thinner the problem is solved (unless the clamp is
broken or something else happens).
Hi pedrofret, Steve has already had the problem solved in an earlier post as shown below.
stevebuk":1xuzqg56 said:
Well frank came over tonight and set to work on the hegner, after about 2 minutes he had sorted the problem, the little round bit and the back of the knurled knob was tight, he used some oil and freed it meaning it will now rotate again, blade sorted, brilliant..
Thanks Frank...
