Blade for Stanley Bridges Husky
mahking51
15 Nov 2004
Nr Dorchester Dorset
Hi All
Have just reconditioned my Husky and now need a blade for it.
There do not seem to be any 150mm diameter blades with a 1/2" bore these days. (Sorry about mixing imperial and metric :oops: )
Anyone have any thoughts, maybe there are bore adaptors or some such available?
Also the method of fixing the blade seems a little odd; there are two wide washers and a kind of sprung washer but there does not seem to be any means of stopping the blade from rotating on the shaft apart from the friction of tightening the centre bolt.
Regards
Martin
:D Hi martin here is a link to some reducing washers. the next time you are in poole go to a shop called INEXCESS in ashly Road Parkstone they buy up bankrupt stock and and sell it on they have some small blade any problems fining it pm me and I will give you directions
martyn :D
Hi Martin
If none of the above works try a reputable saw doctor in your area. For a list see The Saw Doctor Association, or contact them at:
23 Hill Farm Court
Chinnor
Oxfordshire
OX9 4NX
Tel: 01844 354747
Any of their members should be able to supply a blade which fits and/or can be rebored or bushed. If going to a bushing make sure it isn't so large that there is insufficient flat on the blade locking nut to hold the blade (so a 20mm bore is probably out, then)
Scrit
Hi Martin
Back in the 60's the method of fixing blades to saw attachments on Stanley Bridges drills was the washers you mentioned the idea being a safety clutch system if the blade was to snag in the work
It was to protect the motor from burnout
Nigel
I have found a three blade set on Toolstation 150mm x 12.7mm for £7 odd
I do not expect much from them but worth a crack to see how they go.
Thanks for all your help guys!
Regards
martin
