GweithdyDU
Hi all. Just going crazy trying to find square or diamond bitumen roofing washers that fit under the square/diamond curved washers when fixing he sheets down. I've always been able to get them from roofing supply shops/websites, but I've drawn a blank so far. The trouble is, I don't know what they're called and if you type in bitumen roofing" or any other likely useful phrase, Coroline roofing comes up. Does anyone know what they are called?
My stable roof is partly on using the many I had left over from an earlier job so I want to use the same method. I've removed some earlier applied panels and the bitumen washers have a really shiny smooth area where they've been crushed and then heated by the sun; a perfect seal and has been so for decades.
If anyone is interested in the Heath Robinson method that I, as an amateur roofer who is petrified of heights above 18", has developed that works here in the North Wales mountains overlooking the Irish Sea that has worked well for over 30 years on an earlier project on the mountain, here goes (feel free to 'shoot me down in flames if you know what you're on about as I don't!), here goes:
So, if you've read this far and the tears of laughter are running down your face at my inexpert Bodge the Builder method of roofing, you likely know what you're on about so may know what these damn diamond/square bitumen washers are called. Please humour me and put me out of my misery so I can search the interweb for them
Many thanks/Diolch mawr
- Timber frame, traditional corrugated zinc sheets (.9mm) 30ft+length, single incline.
- Screw fixings, even modern ones, work loose and never retighten effectively again, twist nails are pointless and anyway, I hate going on roofs so much, I don't want to go up again, especially in wind speeds that have been known to reach 3 figures, (that one did destroy a Welsh slate roof though!).
- So, instead, I drill the sheet just in-front of the 7" timber joist, etc. that one would usually screw into.
- Then I drill through the timber about 120/150mm down and push a coach bolt through the hole and attach an eye or J-bolt to it via nut with the threaded portion, now poking through the sheet. I then attach one bitumen and 38mm curved metal washer to the other side and use a nylock to hold it down.
- One in every up-corrugation on a leading edge (especially the south-west facing ones), and every-other thereafter. Massive flashings (they really are ugly) and a bead of roofers bitumen in-between overlaps.
