rogxwhit
Merci clogs pour votre input ...
No drawings Jeff I'm afraid, but you can take the measurements off the existing fence stock and fence bar. Do you have the adjuster screw? My original screw was still present, and the width of the way between its shoulders meant that I could make the new block out of 16mm thick bright mild steel.Good afternoon,
I also own a TA 255, sadly without the fine adjustment bracket. You mention that you made yours, do you have any dimensional drawings you drew to work from when making the adjuster? If possible, I'd be interested in a copy of the drawings.
I look forward to hearing from you.
Best wishes,
Jeff
Thank you for responding, rogxwhit, it is most appreciated.No drawings Jeff I'm afraid, but you can take the measurements off the existing fence stock and fence bar. Do you have the adjuster screw? My original screw was still present, and the width of the way between its shoulders meant that I could make the new block out of 16mm thick bright mild steel.
