rogxwhit
I baulk at the term 'table saw', which I see as yet another example of creeping Americanisation, along with things or circumstances being 'awesome'. A circular sawbench is just that and I'm sticking with it. ;-)
This story turned out to be longer than expected (see below). I wanted (needed) a compact saw with a cast iron top for as much under a grand as possible. Hmmm. Tough one. Then in early June I found this TA255. Fairly good nick, 3-phase, but underpowered for the blade size. Price seemed good - I'll buy it and change the motor for a bigger 1-phase one, I thought.
There was quite a bit of rust round the base of the cabinet. But you can buy Startrite Green hammered paint from Paragon - it pleases me to have the historically authentic shade. So I flipped the saw and off went the cabinet to a local spray shop.
And off came the motor. It was 900W, like the TA146 / 165. That's no good for ripping with a 250mm blade. I decided to compromise at 1500W, although the new motor frame was a 90 and I could've got a 2200W the same size.
The old Brook Gryphon was face-mounted but with an obsolete geometry, so I had to adapt the mount for the new motor. A foot mount would've needed a right-angled plate welding up which I can't do in-house, so I chose face mount again.
Here's the adapter plate I made:
The new plate and motor sandwich the existing drop plate and have a small range of adjustment for belt tensioning. The two smaller screws & nuts ride in slots and are 'security' fastenings.
