Best way to stick Polystyrene to MDF
hunggaur
25 Sep 2008
worcestershire
hi folks i ned to stick a sheet of Polystyrene to a sheet of MDF whats the best way to do it
kind regards
jon
double sided tape if it's not going to be subject to much force, or if it is, lots of double sided tape
Aidan
White woodworking glue is OK on polystyrene (doesn't dissolve it) So is epoxy, but it's overkill. Both need some method of holding until they cure.
3M and no doubt others do e.g. water/alcohol based contact adhesives that will bond polystyrene foam too. Also it seems in aerosol form, but don't know if it's available over here: http://solutions.3m.com/wps/portal/3M/e ... e#7_0_382I
I've been gluing polystyrene to painted walls (radiator heat relfectors) with bog standard PVA. I once it's gone very slightly tacky I found I didn't need anything to hold it in place and the bond it such that the PS would be destroyed before it came away.
Alternatively I'd try silicon sealant. Sticks anything to anything :D
