Marcjwebb
I'm not on about new purely second hand. And on fleabay there are various for around the 800 mark.
Is the track saw that much better tho ?
Benchwayze":2vmpkl71 said:The cordless version of the Festool track saw fits a different profile rail; and really was designed for cross-cutting narrower boards.
It is compatiblemarcros":pngp72uf said:that is disappointing to know that the cordless rails are different- I thought that the whole point of the system was that it is all compatible. i would prefer the cordless, simply for the ease of working outside, or in the carpark of the sheet material merchant!
marcros":1hqhvm5y said:that is disappointing to know that the cordless rails are different- I thought that the whole point of the system was that it is all compatible. i would prefer the cordless, simply for the ease of working outside, or in the carpark of the sheet material merchant!
Eric The Viking":13elzmj9 said:petermillard":13elzmj9 said:FWIW TS55 with a 1400 track is about £360. Add £90 for a 1900 rail, £40-ish for the laminate blade. Sheet of 1" Celotex to cut against, job done.
The depth setting is really precise (the Festool is the same) - there's a mechanical advantage of about 2:1 on the scale so 1mm depth is about 2mm on the scale - easy to set very accurately if you need to.
Marcjwebb":10en5vxa said:I'm not on about new purely second hand. And on fleabay there are various for around the 800 mark.
Lord Kitchener":1x0qf1o1 said:It all depends on what you mean by 'chip free'. No saw will give you absolutely chip free, the better ones will give you 'almost chip free'. The only way to get chip free is with a router cutter, which is why serious edge banders have 'pre-milling' which in effect is a router cutter trimming off the'almost chip free' finish left by the beam saw.
Alternatively, cut the panels out with a CNC router.
Marcjwebb":3hwwf0l1 said:ok ill narrow it down a little, i will need to be doing a lot of the same cuts over and over, like 3x2 ft 4x2 3x18" and 4x18" stuff like that,
i mainly need it to be strait, clean and repeatable, is there anywhere in essex i can see a festool or makita or dewalt demo?
Lord Kitchener":3emluody said:Marcjwebb":3emluody said:ok ill narrow it down a little, i will need to be doing a lot of the same cuts over and over, like 3x2 ft 4x2 3x18" and 4x18" stuff like that,
Might be an idea to start thinking and working in metric, will make life easier
RobinBHM":1nv3ciwp said:As a matter of interest how clean can a track saw cut a melamine faced board? It doesn't take much for the thin melamine to chip, it's very brittle.
