Jik":21iy6kzk said:
Great to hear about your lathe ! I have just obtatined an LZ4P Boley..
I am yet to work out how to use the change gears!
How do you get the motor to reverse if you are screwcutting, do you fit a reversing switch, or run it in reverse each time and index the carriage to the same position?
Sorry for the delay in replying and thanks to Tom French for pointing me at it! I've been rather busy and with my wife ill (not Covid though).
The LZ4P is a Boley and Leinen number, not a Boley. They are two different firms, in the same city (Essingen) and B&L split off from B. You will find this interesting:
http://www.lathes.co.uk/leinen/
It is a very good lathe and indeed will do screw cutting. With a lathe with chucks screwed on, as I suspect this has, you never ever run the motor in reverse or the chuck will unscrew and do you and the machine a lot of damage. There is a reversing gear (tumble reverse) controlled by a knob on the front - the lathes.co.uk entry has a picture of it. This changes the direction of rotation of the leadscew relative to the motor. It allows you to do a carriage traverse for bar turning in either direction, or to cut right or left hand threads. Actually, your lathe might have separate screws for thread cutting and for carriage feed (which is good). If it is like the pictures on lathes.co.uk it looks as if the upper one engages (indexes) on the lead screw and the lower one on the carriage drive for turning rods.
In this style of lathe you do not run it in reverse at the end of a screw cut. You stop the traverse at the end of the cut (normally just past the end of the work), disengage the index lever, pull the tool back with the cross slide, wind the carriage manually back to the start, then advance the cross slide to cut a little deeper and re-engage the index. Sounds elaborate but it's the way I was trained and you pick it up quickly. You may have a single index position or several, in which case they will be numbered. These are for doing multi start threads and you must use the same number each time.
In principle you could engage the reverse to wind the carriage back, but this would be much slower than doing it manually. And on a lathe that has seen much use, there would probably be some backlash at the lead screw so the tool would not actually run in quite the same track and would chew up your thread, so you still have to withdraw the tool (or use a flip holder).
I'm not au fait with the details of Boley Leinen lathes but can probably advise you further if you ask specific questions. But only if you post copies quality pictures for us all to admire!
Keith
