BlackMerlin
New member
Hello,
I'm planning to make a simple internal window sill to sit on top of the previous sill (old clay tiles). I've got 190mm oak boards and have made sills out of them for most windows but I've got one window with a big recess that needs a ~300mm sill. My plan is to glue two oak boards together like you would do for a normal panel and trim as needed. I'll then use CT1 to glue the panel on top of the tiles. This has worked well with the other sills and provides a level of flexibility for the wood.
The way the window is positioned I expect people will end up siting on the sill quite a bit and I'm wondering if just gluing the two boards together will be enough considering the forces that might be applied to the individual boards and the flexibility of the CT1 adhesive underneath. Is there a better joint I should use? I was wondering about a half-lap for example. Tongue and groove would be another but I'm not sure I can manage that as an amateur with just a router.
What would you suggest?
Many thanks!
Many thanks!
