matt
Having read numerous and lengthy threads about the value of Bessey clamps I've been debating whether to add to my very small collection of cheap Besseys...
Today I was using the existing ones to make some panelled doors. I have two UniKlamps which I used for the first door. For a start they're light so I could assemble the door on it's edge and then leave it there as I put the clamps on. When tightened the doors sat nice and flat against the bars. I then lifted the whole assembly out of the vice and stood it on the floor.
Having used up my ONLY two UniKlamps had to take a whole different approach to the next door. For a start I was using a couple of Record sash clamps. I had to set out two workmates and set the clamps up beforehand, making sure they were the right distance apart etc. Stood the door on its side on top of the clamps for assembly before twisting it through 90 degrees and dropping it between the jaws of the clamps. Tightened the clamps and then peered underneath to see how tight the fit was to the bars. Not very... Tried slackening the clamps and adjusting but it was not playing ball. Fished out two more clamps to hold the doors flat against the bars.
So... for doors and similar, and at <£12 each, I think the UniKlamps are very worthwhile. (Especially once you've worked out the knack for sliding the clamp head up and down the bar!)
I've yet to experience the K body clamps...
