Hornbeam
I am making a circular cabinet which will be made in sections, I am looking at using 1.5mm ply for the laminated sides but want to bulk the thickness out so was thing ing of using 2 central laminations of 5mm bendiply with 2 outer 1.5mm ply skins on each side, which will then have an external and internal veneer applied. I have never used bendiply but have a couple of questions
Ian
- Is it all the same quality or is it a bit like ordinary ply. some good some carp
- What is the glue quality
- I understand the laminations all run the same way. Is it dimensionally stable as I dont want to have movement issues if I am laminating it with thin ordinary ply
- Any other thoughts/comments
Ian
