Baldhead
What is the difference between beech and steamed beech?
Baldhead
Baldhead
Nor me. I just thought it would make it softer and easier on the teethdavid123":1perq309 said:We'll
I never knew that :shock:
Thanks for that.Sgian Dubh":ksd56ftu said:Steaming causes a chemical reaction in the wood and changes the colour to a quite uniform pink as opposed to the off white/brown colour of unsteamed beech. It also makes the wood somewhat easier to work with cutting tools (without going into the minutiae of the details). Slainte.
You would need a decent well insulated chamber; a kiln, perhaps one as described by Giff in other posts, might do it, but I'm not sure. The essentials of the process are that the wood is stacked in the chamber and you have to raise the temperature inside with hot wet steam to about 100ºC. It takes time for the wood to rise to this temperature, but it's critical that it does so, and then once you've raised the wood to temperature you need to maintain it at about 95%- 100% RH for about 18- 24 hours.david123":3tqhx8rz said:Any idea how long it has to be steamed, and could it be done at home? I have some beech and would like to give it a go. Very interesting
