Bargain Jewellers saw
If you have the German type shown in this thread, affix the blade first, then grab the back of the frame and put the excess spine against the bench and lean on the saw with one hand while tightening the top screw with the other. Make sure you tighten the top firmly or it'll just slip.
xy mosian":3j4tlr9t said:
David C":3j4tlr9t said:
Regular fretsaws have very little tension.
David
Ah it is the available tension then. Thank you.
When I have needed more tension on the fret saw I just shorten the blade. Or sometimes the blade shortens itself.
xy
David, I do not like the tone of my reply. It is me thinking out loud trying to persuade myself not to spend money. I apologise, Thank you for taking time to answer.
xy
XY no worries! I think there is a nomenclature problem here.
Fretsaw implies fretwork or Marquetry to me. These fretsaws have something like 15" throats. This being the reason why high tension is not available.
The model shown is a Jewellers saw, used for cutting thin metal sheet, as well as other things. For this work high blade tension is very desirable.
The expensive Knew concept saws take outstanding tension, and seem to have been welcomed by many woodworkers for sawing the waste on small dovetails. When dovetails are very large, the coping saw comes into its own.
Best wishes,
David
For anyone interested, here's a table of tpi's for jeweller's saw blades -
Size Thickness Blade Depth(inches/mm)
Teeth Per
8/0 .006″ / 0.15mm .013″ / 0.33mm 84 Per Inch / 33 Per cm
7/0 .007″ / 0.18mm .014″ / 0.36mm 84 Per Inch / 33 Per cm
6/0 .007″ / 0.18mm .014″ / 0.36mm 76 Per Inch / 30 Per cm
5/0 .008″ / 0.20mm .016″ / 0.41mm 66 Per Inch / 26 Per cm
4/0 .009″ / 0.23mm .017″ / 0.43mm 64 Per Inch / 25 Per cm
3/0 .010″ / 0.25mm .019″ / 0.48mm 57 Per Inch / 22 Per cm
2/0 .010″ / 0.25mm .021″ / 0.53mm 53 Per Inch / 21 Per cm
1/0 .011″ / 0.28mm .023″ / 0.58mm 51 Per Inch / 20 Per cm
1 .012″ / 0.30mm .025″ / 0.64mm 47 Per Inch / 19 Per cm
2 .013″ / 0.33mm .027″ / 0.69mm 44 Per Inch / 17 Per cm
3 .014″ / 0.36mm .029″ / 0.74mm 40 Per Inch / 16 Per cm
4 .015″ / 0.38mm .031″ / 0.79mm 37 Per Inch / 15 Per cm
5 .016″ / 0.41mm .033″ / 0.84mm 35 Per Inch / 14 Per cm
6 .017″ / 0.43mm .037″ / 0.94mm 33 Per Inch / 13 Per cm
8 .020″ / 0.51mm .045″ / 1.14mm 28 Per Inch / 11 Per cm
10 .024″ / 0.61mm .053″ / 1.35mm 24 Per Inch / 10 Per cm
12 .024″ / 0.61mm .065″ / 1.65mm 20 Per Inch / 8 Per cm
14 .024″ / 0.61mm .067″ / 1.70mm 16 Per Inch / 6 Per cm
Not really woodworking sizes, but I have used the coarser ones for coping ogee skirtings - it takes a minute or two longer, but the fit is perfect. The drawback is that the blade doesn't swivel like a coping saw's.
Without the higher tension they snap before you can blink.
(I usually use 3/0s for silver.)
Definitely not an un-considered purchase I think. The best part in that saw, for me, has to be the bungy cord. As new, and good as the saw is, still the 'old' ways (used to be a bit of nicker elastic) have a place.
xy
AvE is a youtube tool review channel that really tells you about the tool. Bloody good too
