matthew
Currently have a Metabo BAS317 which is good, but a couple of things lacking - the fence is not easy to make minor adjustments to - and the power; the capacity of 165mm is actually OK for most things, but the 900/570W struggles with resawing a hardwood board (even after upgrading to a tuffsaws blade!).
But overall I enjoy using it and, and am thus prioritising upgrading it over a bigger TS. Considering Record BS350 or BS400; or Charnwood W730 or W740 (a new-ish model).
Is it worth considering a 14" as an upgrade from 12"? The Record BS350 isn't that much bigger, but has (I think) 1100w output power so I'm thinking would resaw eg 150-200mm timber a lot better than mine.
Space is limited in my shop so size and mobility are concerns, but OTOH a 16" is tempting. The Record seems the obvious choice, but the Charnwood has two things I like the look of more: a better-looking fence (with micro-ish adjust); and bearing blade guides as opposed the the flat-type thrust bearings (which are on my Metabo). Are either of these an issue for current Record owners?
A bit of a vague request, I realise! But if anyone has any comments/suggestions, much appreciated!
