promhandicam":36ppd7t5 said:
I don't know what is suggested for the 401e but in the manual for my 502e it says to position the blade so that the teeth are on the edge of the wheel - presumably so that they don't damage the tyre. If it is the same for yours, this may be why it is difficult to get the blade to track as the damage is on the front edge by the looks of it.
Steve
Steve, I think you've got it! :wink: My manual says the same.
I've been out there this morning, cleaned everything up (didn't need a lot of work) and have fitted a 1/2" blade centrally on the wheels - it seems fine. I had to re-adjust the tracking on the lower wheel slightly but, it's not moving and it's certainly not going to fall off.
At the moment, I'm only able to rotate the wheels by hand as I'm not yet wired-up for 16amps. But I'm doing this for at least thirty-seconds, as the man from Startrite advised.
If you look again at these photos:
It looks as though he might have been doing the same with narrow blades as well (I could be wrong and that could just be where the teeth were running on blades of varying width).
I haven't yet tried the big 1" blade I've got because I need to practice coiling a long blade again before I let that one out!
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I can't imagine any of the other blades having any trouble with this, though.
It might be nice to try and fill it one day but, I agree with kasandrich; you can do a lot with narrow blades and they're a bit cheaper to replace.
Well, it looks like I could be worrying over nothing although, we won't know for sure until I get some power running in to it.
Why would you run a 25mm blade with the points protruding over the tyre though? Is it to do with the camber of the tyres?
