Benchwayze
I fitted a new, 3 TPI skiptooth , 1/2" blade to my Startrite 351 today.
I wanted to re-saw some 6"x 2" cedar into 6 x 1's.
I finally managed it, but for some reason the blade keeps up an irregular 'thumping or jumping into the cut. I think this might be vibration.
I am advised on various websites to increase the tension, yet the manual for the saw tells me tension should be ' low to medium' for the blade I have fitted.
The tyres are clean and there are no heavy wear ridges in them.
Blade runs on the crown of the wheels, no trouble and the sandwich-guides (A bit primitive on this machine) are set as close to the recommended settings as I can get with feelers. There is no excessive heat or smell of burning, and no sparking from the rear guide.
I have owned this saw for 18 years and have kept it up to snuff. I never had this problem before. I know that blades will squeal a bit on deep-cuts, but it seems as if the saw blade is slipping around the wheel now and again, causing this thumping in the cut. I wondered if this irregular thudding and jumping is what is known as vibration. I suspect that increased tension will help, but I have the tension quite high at the moment. It doesn't get worse as I decrease tension.
Does anyone know what this might be caused by, as it's ruining some good timber on deep cuts.
I'd appreciate any pointers.
Thanks in anticipation.
John ccasion5:
John ccasion5:
