Bandsaw - £1-1.8k range
My assumption is that is discontinued in favour of the Sabre line.
Yes it has been superceeded and the sabre fence is now available as an upgrade for the BS400. The sabre 450 is really an updated 400 with an extra 2 inchs of cut and upgraded fence and blade guides, along with the price.
I bought from the Axminster 'Workshop ' range (for serious home hobby use) and I am very pleased, having had experience of several professional machines. Re-sawed 4" x 3/4" softwood ) straight out of the box, and the two 'Axcaliber ' ground blades and mitre fence extras are very impressive.
Setup instructions more than adequate .
Thanks all, think I am heading towards the 14BX since quite a few have voted for it, and the wisdom is to buy slightly more than you think you need (want).
I have the 14/12 and happy with it. It's plenty of power. I've done a little bit of resawing. Cutting through large green logs etc and it's handled It well. It has a few minor niggles, and if I were to buy another I'd go for the BX.
Also I recommend getting a variety of blades for your needs from tuffsaws. Having the right blade for the job helps significantly.
Is your BIG Scheppach up for sale yet? . . .
Yes it is or could be , I think it is the Basato 5-2 single phase 240 volt , It runs from a std 13 amp supply, I have installed a new set of guides all 6 at the cost of £170.00 ( Not set up yet ) as I decided to sell , The table needs to be removed when transporting, The table is cast iron and is very heavy, to heavy for me to lift now in my old age 😟 " IF " you are serious regarding buying let me know and I will list it on here.
