Hi Folks
I am a novice woodworker with a long list of projects that will require the use of Forbo Desk Top Linoleum on a ply backing - the Forbo is a 3mm linoleum product that comes in roll form and is will be glued to the ply.
The first project that I am going to undertake is a large coffee table - apron 1.6m x 0.8m with a Forbo top and I have a technical question that I haven't been able to find an answer to -
The Forbo installation Guidance Note Says that I should use a backing material to counterbalance the panel - a bit like a balancing veneer...
It suggest ideally using the same material - (which is pretty expensive) - but it goes on to say that
"A variety of materials can be used as backing if the Desk Top or flooring material is not being used on both surfaces but as individual installations will vary so much the safest solution for any surface considered to present a risk is to do a trial first"
SO MY QUESTIONS ARE "
Does anyone have any experience of this type of material in the real world and -- if so please can you advise on whether an alternative backing material would work and if so what might be suitable?
For Clarification - I am thinking of using 18mm Birch Ply backing, and expect to fix the table top to a subframe, although the edges will not be directly supported within 200mm of the edge (bit of a cantilever)
I also intend to use this for some cabinet doors - where the backing question will apply in a completely 'unsupported' way.
Any advice would be welcome...
