GazPal
bugbear":3tmfjiu0 said:GazPal":3tmfjiu0 said:Adjustable mouthed planes are what they are and can/should be adjusted to suit the timber being planed and degree of blade set in use. Otherwise you may as well purchase a wider selection of standard non-adjustable planes and use frog adjustment as a means of varying the throat.
But there are very few (that I know of) adjustable mouth bench planes (as opposed to adjustable frog).
Could you mention the ones you're thinking of, outside the re-incarnations of the Stanley #62, #164?
BugBear
Stanley's new incarnation of the #4 is the one that immediately sprang to mind prior to posting earlier, but the same approach can be taken with LN's #62, #164, Veritas bevel up smoother and jack, plus adjustable mouthed block and shoulder planes. The practicality of an adjustable plane compares favourably to non-adjustable counterparts and potentially reduces the number of hand planes needed within a kit.
Older examples of adjustable wooden planes include smoothing and panel planes with sliding steel nosings that are used when varying throat aperture.
