When buying cheap and cheerful machines you should also buy some headache pills in readyness to help with the stress and brain ache.
I wish that were true! As I found with my old mitre saw, when you're working in a small space an oversized tool really can be a problem...My advice is, always buy the next size up from what you think you'd like!
Especially large machine tools.
Phil
Before I bought the saw I'd read plenty of reviews and comparisons saying exactly that, but in my experience the Makita saw gave a pretty rough cut and loads of scorching on the wood. I tried various blades and speed settings, no difference. I even sent it back to Makita under warranty and they told me it was absolutely fine. I assumed it must have been some error in my technique or even a bent guide rail, but since switching to the festool my cuts have been absolutely perfect using the exact same rails.
You might be on to something there, I never even considered that as it's "common knowledge" plywood doesn't move in that way! I never noticed any movement in the wood but if it was a small amount it would be easy to miss so I'll pay more attention next time, but the riving knife on the festool should help as you sayAm I right in thinking that the Makita saw does not have a riving knife....?
Certainly, recently, a lot of sheet materials I've bought have a lot of internal stress in the materials. Without a riving knife, I would imagine the blade could get nipped up as the stress is relieved during a cut.
I was breaking down a sheet of MFC yesterday that was delivered on Monday. 2800mm x 2070mm x 18mm sized sheet.
I cut about 15mm off the long factory edge, moved the rail over 122mm, made another cut and the piece was bent like a banana with about 30mm deflection in the middle. I could visibly see the cut closing up behind the saw as it proceeded down the track.
Without the riving knife on my Festool saw, I can imagine it would have caused a rough cut with burning.
No it has no riving knife but do you need one on a tracksaw, only the dewalt and festool have one.Am I right in thinking that the Makita saw does not have a riving knife
Well,....Obviously Festool & Dewalt seem to think a tracksaw warrants having one.No it has no riving knife but do you need one on a tracksaw, only the dewalt and festool have one.
But then Bosch, Makita, Mafell & Milwaukee don't so cannot be essential like on a tablesaw.Well,....Obviously Festool & Dewalt seem to think a tracksaw warrants having one.
With the Makita I never felt confident that it could (or should) rip solid timber, it was reserved solely for sheet goods. Now I have the festool I'd be much happier ripping solid stock and it also opens up the option of using it to "plane" one edge straight before cutting on the table saw.
So I guess the riving knife debate comes down to your intended use for the tool?
It's a long time since I bought a tool and regretted it, I have learnt to only buy the good stuff, I also have pretty much everything I need so am not tempted by special offers etc.
I hate things that aren't well designed, if you use something a lot a minor niggle soon becomes a major niggle, the more expensive stuff generally gives you an all round better user experience and just works better.
The last purchase I made and regretted was in fact some of the Forstner bits from Lidl which were mentioned earlier, I opened them, tried one and threw them straight in the bin promising myself never to buy cheap rubbish again!
Maybe they include a riving knife because it costs them about £0.15 each saw and they know it will get them some sales over their competition?Yes...,It does seem odd that all the other manufacturers dont think its necessary.
Personally, it just gives me peace of mind knowing that should the material being cut start to bind on the blade, then the riving knife should help to prevent the blade from nipping and causing a kick back of the saw.
