Backup software recomendation
Well for anyone looking for software to perform backups of there precious data and files I can recomend GoodSync which I have been using for a while since dropping Genie 9 due to many issues and Acronis true image which has lost it's way. Backups should be simple and reliable and this Goodsync software is delivering, what I really like about this program is that unlike many others that just perform the backup and then give you the statistics of file numbers that are new, changed etc this one performs it in two stages and in full view using a file directory structure. The first is the analyse part which shows all the files and folders in your backup, on the left are the chosen files and on the right the files in the backup and you can see any new files or ones that have changed since the last backup but at this point nothing has been done, it is just showing you any changes. Then you can sync the files which updates the backup to the latest versions from the Pc and this is also clearly shown. There are many other options and it can syncronise in both directions, so not only for backups as if you have worked on your laptop and these files are newer then it can update the files on the Pc and of course vica versa and backup to multiple drives. You can use it for free, unlimited time but there is a file limit which allows you to see if you like it and to buy is only £20 so I believe is good value. I will say that I have no connection to this company or it's products and that I am just giving a review of a product that I have used and think might be of value to others.
Try SyncBack by 2Brightsparks. They have a free version as well. I have been using it for like 20 years.
Hi there
I am now using Goodsync, I find this software to be a breath of fresh air when compared to others I have used such as Acronis and Genie. It is quick and simple with a listing like file manager that shows all the files that have changed and then you can just back them all up.
I no longer backup any programs or take disk images because I found they were more trouble than not, these days just as easy to do clean installs and clear out the junk at the same time. I will look at syncback for future reference.
Has anyone mentioned Acronis True Image I have been using it for 3-4 years now. It has good support.
I have used acronis and rated it, however when a backup fails to restore it kills your faith in the software. I can't trust it to work so it doesn't get a second chance.
