Axminster "white" range sanders
Eric The Viking
19 Jan 2010
My very cheap and very old orbital sander started smelling nasty yesterday, and almost stalling, although I'd just stripped it and cleaned the commutator and lubed the bearings. It's beyond salvage, I think as an inaccessible bearing has broken up.
I note that Axminster have 'white' range sanders on offer, affordably for me.
Has anyone had any particularly good or bad experiences of them - the sanders, I mean?
Thanks,
E.
I had an axminster white palm sander and it was bloody terrible - the vibration was so much I wouldn't put it any where near my boxes, it now sits in the corner gathering dust.
Best
Ian
Thanks Ian.
I'd pretty much talked myself into a variable speed Makita - expensive but really well made (by the look of it).
Still pondering, but I need to get an order in tonight so I'll probably go with it.
I thought the white ones looked a little too good to be true...
Cheers,
E.
I got an Axminster one this year, (125mm square) and it is the old fashioned type where a lever is lifted and sand paper is then trapped (front and back).
I punch extraction holes with a paper punch and have a very varied selection of grade choices. (I think it was around £18)
Also got the Bosch velcro fixing type which I use for 60 or 80 grit cleanup work.
Both work for me, but most probably neither reach the standard of Ian's requirements.
Well, I've gone with the Makita (and a paper punch!).
I looked at some of the cheaper ones in Wickes* and B+Q* yesterday and (without turning one on) was quite unimpressed by the build quality. I know that's not Axminster, but when you see them all side-by-side, you quickly realise there's one little corner of China...
Had an amusing conversation in Wickes:
Me, "Have you got dust hoses for the sanders? I notice they all come with an adaptor and take the same size..."
Staff person, "No mate. Never kept 'em."
So much for elf'n'safety.
E.
(*was chauffeuring the Domestic Controller, so had time to kill - don't normally darken, etc.)
