EWS":3txva8u2 said:Had a great time in SpainBut now I am looking forward to get in the sawdust, an dig in for the Winter up her in the North
The TS250 mk1 manual states 80mm as max depth of cut, whereas the mk2 is 76mm max, presumably they have altered the table and/or blade holding mechanism which results in a 4mm loss of depth.rhencek":3ultgdql said:Yea I read it on page 40 of pdf manual. OK I understand. I ask because czech manufacturer PILANA offers grooving blade with a 5 mm tooth width at the thickness of a 3.5 mm. I think that this is quite good alternative (cost 22.- €) to regular Dado blade.
Richard
thnx for explanationBodgers":2nn1hpor said:The TS250 mk1 manual states 80mm as max depth of cut, whereas the mk2 is 76mm max, presumably they have altered the table and/or blade holding mechanism which results in a 4mm loss of depth.rhencek":2nn1hpor said:Yea I read it on page 40 of pdf manual. OK I understand. I ask because czech manufacturer PILANA offers grooving blade with a 5 mm tooth width at the thickness of a 3.5 mm. I think that this is quite good alternative (cost 22.- €) to regular Dado blade.
Richard
Maybe 85mm is theoretically possible with a 250mm blade, but this will be overidden by the saw it is sat in...
Sent from my MI 3W using Tapatalk
MikeJhn":2cfvhc2i said:Slightly better pic of the riving knife:
Mike
