Have you (or anyone) ever taken off the cast iron top.
I got my ts250 in an axminster clearance sale, and got it really cheap(Paid£300) because the top is squint to the frame, and its off by 5 or so mill.
What that means in real time is I can adjust the blade so it is aligned to the slots and fence for 90 deg cuts, but if I cant the blade to 45 deg, the leading edge of the blade impacts the table, and if i square it, its not going to align totally to the slots, and putting the blade back to 90 deg its well squint.
So what I think i need do to rectify it, is to remove the top, then elongate the holes into the frame, so I can actually align the table to the frame, before tightening it up. This would mean at that point the blade at either 45or 90 would align to the slots and the fence.
Anyone see that as the solution ?. I know you cant see what im seeing, and i think just opening up the holes on the frame is the answer, though at the same time I can see that id need washers underneath, and maybe fill in the excess gap with epoxy in case the table moves in use. I dont see that actually happening, but because im creating room for it to move, I think i should do something to prevent that from happening once Ive squared one to the other. Just eliminate the possibility
TBH, I think given the hassle its caused, and trying to avoid doing long mitres, id have preferred to spend that extra 200 quid. But hey ho, only had limited funds at the time and it seemed like a great deal then
Im intending on selling it, to be replaced with a 14" bandsaw and plunge saw. But it needs to be sorted before i can do so.
