JamesP7
Ok so it seems to be working at the moment! - I have had a response from Axminster and it is very similar to what you have said above - "the two nuts lock up against the inside of the casing, they have undone and are no longer keeping that bar under tension hence causing it to flip out the hole and fall out. The bar needs to go back in the hole and tensioned at the lowest point."
I did this but the threaded bar would fall out of the hole before the saw blade could reach the 76mm maximum height, maybe 65mm proud of the table or so. There was a little play/wiggle in the frame of the height mechanism, but by tightening the 2 Phillips head screws/nuts on either side of the frame, this stopped the wiggling happening and then enabled me to raise the blade to its maximum height without the bar falling out of the hole.
I do wonder if the frame of the saw has bent a little making the distance a fraction larger between the plate of the locator hole and the rest of the welded part of the frame, causing the threaded bar to lose its tension :?
I asked if there should be a pin on the end of the threaded bar, Axminster said that although it appears to have one in the manual, the servicing department said they have never seen one there before on this model of table saw. Hopefully this has sorted it for the long term, thanks again.
James
James
