Thank you, edit made.MikeJhn":3a8u5j8o said:"but I think it's important not to rule out something for someone else based ON what could be a personal preference."
Back at you.
Mike
Mark A":1z1koanb said:Would a grooving blade work?
http://bivenmachinerysales.co.uk/index. ... uct_id=790
It says the 5mm and 6mm blades have a plate thickness of 3mm.
Sent from my Moto G (4) using Tapatalk
woodbrains":21g3k340 said:There is ALWAYS another way to cut housings that is safer, more efficient and less of a hassle.
transatlantic":lfr2pq0d said:woodbrains":lfr2pq0d said:There is ALWAYS another way to cut housings that is safer, more efficient and less of a hassle.
What could be more efficient? the only thing I know of would be a router, and that takes several passes and arguably more of a hassle to setup and use.
memzey":1oz1e93i said:With all due respect setting up a dado stack needn't take much longer than a minute- even with shims. Test cuts would need to be done with the router as well given the nominal thickness of stock compared to the engineered thickness of the bit. Stopped housings are possible with a dado stack but need a few swipes with a chisel to square up (as do routed variants). As for cost - I paid about £115 for my stack which covers any thickness from 1/4" to 29/32" in .004" increments. Consider how much it would cost to purchase the equivalent tooling for a router from say Wealden (if they are all available). Safety is always a concern and no less so when using a router or router table. As with most things in life there is more than one way to skin a cat (we haven't even discussed use of a spindle moulder). You pays your money and you makes your choice. That being the case I find absolute terms like "always" and "never" in this context a bit unhelpful.
Tealeaf":amj1b7gh said:Thank you, edit made.MikeJhn":amj1b7gh said:"but I think it's important not to rule out something for someone else based ON what could be a personal preference."
Back at you.
Mike
MikeJhn":3dkoofqt said:No, Arbor length is not suitable, using a Dado is not the right way to grove anything, use a Router/Table.
Mike
