• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale Axminster AC254TS Table Saw 230v with Cabinet Stand and Wheeled Base
Puggers
29 Oct 2018
Northallerton, North Yorkshire
I've owned this from new having taken delivery in June 2021 since when it's had limited DIY use only.
I bought the saw along with the optional upgraded cabinet stand and heavy duty wheelbase which are included in the sale along with a 40 tooth blade, spare table insert and additional riving knife. The original user booklet is available and I can show the buyer the purchase documents.
The cast iron table is clean and rust free with no signs of damage throughout the body panels of the saw or cabinet. The wheeled base can obviously be removed and I have the unfitted original static feet for the cabinet.
Dust extraction is via a 100mm outlet to the rear but which is coupled to a 63mm hose attached to the crown guard. The cabinet has a storage area door on the right-hand side.
Specification -
Power 1.5kW induction motor
Blade diameter and bore - 254mm/30mm
Max depth of cut at 90° - 80mm
Max depth of cut at 45° - 56mm
Max width of cut with fence - 430mm
Twin 19mm slots which extend to the rear extension table
Dimensions -
Cast iron top - 485mm x 680mm
With right hand and rear extension tables - 760mm x 900mm
Main fence - 765mm long x 43mm high x 60mm wide (excluding the removable auxiliary fence)
Height (on mobile base) - 912mm
Weight - 89kg
The photos show the saw fully put together although the tables have now been removed for safe/dry storage pending sale - it will take c20 minutes to reassemble. Given the weight, this is a two-person lift and with the tables off, it should, with care, fit into an estate/SUV or large hatchback if a van isn't available (the buyer should check first please).
I can arrange a short video of the saw running if genuinely interested and requested via DM. More photos are also available.
The buyer will need to arrange their own collection after viewing in Northallerton, North Yorkshire and I'll be on hand to help with loading. If the buyer isn't travelling too far, I can possibly follow on to help with unloading and assembly.
I'm looking for £525 inclusive.
    68.6 KB
    51.3 KB
    65 KB
    75.6 KB
    57 KB
    61 KB
    57.7 KB
    73.3 KB
