bp122
Expert at Jibber-Jabber
I have had this fence for nearly 9 months now (haven't stepped into the workshop in the last 4 due to my first off-spring being born )
I have never been happy with the fence, I must say. It doesn't wobble or anything but it doesn't stay true. After every cut I need to measure if it is parallel to the blade. Instead of giving me a solid feedback upon locking the fence, the locking handle has a mushy feel - The kind I am used to getting from chocolate steel parts in cheap mowers or tools.
The welded sheet metal extensions on the side is half responsible for this, as the spot welds are really bad and it has a bow, so the fence rail doesn't sit properly, as a result it affects how well the fence sits once locked.
As a result, I have decided to make my own rip fence by:
1. Taking out both the rear and the side painted sheet metal extensions out
2. Removing the fence
3. Build an fence out of stable birch ply, running on INCRA tracks (actually just a couple of quid more than the cheap china stock on fleebay) on front and back - into wooden extension tables which also houses my router (currently don't have a router table) - This way same reliable fence can be used for both the table saw and the router table, whilst being able to use the right hand side mitre slot on the table saw top for mitre fence for the router table as well.
4. Increase the rip capacity from just over 400mm to 550mm (I don't use it to break down large sheets, got a track saw for that. But I have found that most of my projects tend to require round about 500mm rip capacity.
This is a wish list at the moment, but as soon as I get the weekly 2 hour pass in the workshop from SWMBO and the little pocket square, I will crack on with it.
A few items on the list I suspect might change, but not the agenda. Because I CANNOT LIVE WITH THAT FENCE!
The mistake I made is that I didn't use the saw for almost a month and a half after I bought it as we had just moved in and other bits were prioritized. When I did run it, I knew too little about saws and their intended performance to approach AXI about the issues.
Otherwise, I'd pick this table saw over any in similar price bracket, especially the brushless shouters.
One silly inexperienced man's opinion of course!
