AndyT":13k6inum said:Phil, sort of nearly answering your question - in the context of fixing skirtings, I know it was ordinary practice to fit several plugs, then trim them to a common line, ready to nail skirting to. I've seen this described in old textbooks and observed it in my Victorian house.
And for many fittings, you'd probably do something similar - flush the plugs, nail a batten across them, then screw your shelf brackets or whatever to the batten.
Cheap, simple, easy to do, effective, possible with just offcuts - no purchase necessary.phil.p":1xpplhpk said:What is the point of cutting them off flush with the wall? All that endgrain for the rain to track through? But then, I don't understand why anyone would choose to use them at all.
No skills":1pq4kyxv said:Having tried to fix various things to the insides of some old houses I can certainly see why they were used - replacing skirting on our own 1890's house would of been easier if I had known this method. Fixing into uneven weak mortared crumbly brick is no fun.
