Grahamshed
The results for the Autumn Challenge are now in and are made up as follows.
My thanks to Paul Hannaby, judging the entries must have been a difficult task.
Judge's Scores
As an experiment I have added more of my thoughts as constructive feedback. It would be interesting to hear if the entrants think this is better or worse! Bear in mind that it's just my opinion.
Results (and feedback) as follows -
1. Monkeybiter: Good cup shape, perhaps a tighter curve at the bottom of the cup would have improved it further. Some bruised grain inside the cup (often a difficult area). Captive rings well executed. Thin foot makes the whole piece appear lighter and well balanced. 10 Points
2. Dalboy: An unusual combination and technically challenging. The cup has a nice outer curve but appears detached and incoherent from the rest, perhaps the cage at the top of the stem is too big and separates the cup and stem by too much? The inside of the cup appears flat at the bottom, not reflecting the outer curve. The base is well finished and in proportion. Perhaps the stem could have been thinner with a more pronounced curve? Well finished overall. 8 Points
3. Dennisk: The colour of the stem echoes the colours in the spalting but I'm not sure the foot goes with either. Nice shape to the cup, perhaps a little fussy at the bottom with too many details. Perhaps more curve to the stem would be more coherent with the cup? The detail at the bottom of the stem reflects part of the detail at the bottom of the cup. The foot appears heavy and has a hole in it. Cleanly finished base and well finished overall. 6 Points
4. Castanea: Detail at each end of the stem delineates each element of the goblet and improves the overall look. The foot looks too heavy. A little bruised grain in the bottom of the cup. Cup wall could be a little thinner. Parting off of the foot not cleaned up properly, leaving visible rings. 4 Points
5. Dedee: Cup outer curve is inconsistent. Transition from base to stem could be blended better to avoid the step or perhaps some form of details at the bottom of the stem to divide it from the foot would avoid the problem. Centring the blank away from the pith would strengthen the stem and would avoid the stripe down the stem. Some torn grain under the base - sharper tools needed! 2 points
Steadyeddie: First impression is that the cup seems small in proportion to the rest of the goblet and the stem and foot are quite thick, making the goblet appear heavy. Cup and base appear well finished.
Well done to all who entered. I wish more people would have a go!
Regards
Paul
Entrants' Scores
( Just to explain this, contestants vote for their top 3 to which I allocate 3 ‘votes’ for first, 2 ‘votes’ for second and 1 ‘vote’ for third – rocket science eh ? )
Votes were received from all of the entrants totalled as follows
1st Dennisk with 22 votes = 5 points
2nd Dalboy with 8 votes = 4 points
3rd Castanea with 6 votes = 3 points
4th Monkeybiter with 5 votes = 2 points
5th Sreadyeddie with 3 votes. = 1 point
I would like to thank all the entrants for taking part, I thought the general quality of the entries was very high and would not have wanted to be the one doing the judgeing. I hope you all find Paul’s extra feedback useful.
So ….
Overall Scores
JOINT FIRST place with 12 points each = Monkeybiter and Dalboy
3rd place with 11 points = Dennisk
4th place with 7 points = Castanea
5th place with 2 points. = Dedee
Congratulations to you all. Let us hope there are more entries next time.
Mod Edit:- Original Autumn Challenge entry thread.
Judge's Scores
Regards
Paul
Entrants' Scores
So ….
Overall Scores
