• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Auto master/slave switch
I would go DPDT….
DP= Double Pole - it switches two wires
DT= as above
this allows both live and neutral wires to be switched.
There are also ‘DPDT Centre Off‘ switches which do what they say - there is a central off position where there is no connection.
Understood. Thank you very much for the clarification.
FYI - for anyone wondering what kind of load is required for "multi-way extension block to the tool socket" option HamsterJam suggested here - with the auto-switch model discussed in this thread - I found that 20W 11W dummy load on the master socket is sufficient to turn the slave socket on.
Update: turns out 11W in Master socket works to trigger Slave socket just as well
rather than unplugging and plugging in the vac, if you have changed the master socket to a multiway or have a multiway extension plugged into the master socket. get an old small table lamp with a 25w bulb and switch the lamp on which will bring the vac on.
Thank you for the suggestion.
Yes, this is exactly what I did and eventually found that with 5W lamp in the multi-way extension it does not trigger slave socket, but with 11W lamp it does.
Will probably have to do some more permanent re-wiring eventually, as table lamp in a quarter garage "workshop" takes too much room :), but my main issue with having to plug/unplug cords all the time is now sorted, thanks to nice people of this forum.
for anyone who has one of these (yep, thanks) this is what the insides look like so easy to modify if required to build in to a different housing perhaps
Da woodster said in an earlier post it had an internal 13A fuse ( I must admit despite opening it up, and it has a silly security screw to hold it together, I didnt read the fuse value.
I actually dont see the point of the internal fuse unless it is a quick blow one (hope not)
Just opened the case again to see the fuse value. its 10a. with an L marker so low capacity what ever that means.
Ignoring the price - if it is 230V Maxvac version with 2000W power take off then (on paper) it is indeed a better option than the switch discussed in this thread.
sounds like the power on/off is a little tricky and cables are a little thin so glad I went for the upgrade with it built right into the vacuum
For anyone wondering - cables to Master and Slave receptacles of the switch are 0.75mm and the mains one is 1.0mm
