woodbloke
I was doing mine though in the AirPress which does make it slightly easier as you don't have to worry about uneven pressure (as you would do if pressing 'twixt boards, which is how I used to do it)Chems":3g9fluhn said:I was thinking about you as I was doing it actually Rob, a whole cabinet veneered, the stress! I just used masking tap and it came off fine and the marks left were gone when I sanded it to 240. It was commercial veneer at 0.6mm and I was thinking about what you were saying about not having to worry about sawing through your slightly thicker home made ones whilst I was doing it and fretting that any second MDF would show through!
The TB3 did the job, I would have just liked to have been able to sort of stick it down by hand before applying final pressure. But the TB is so liquidy which is normally great that the natural curve of the veneer kept lifting up. Came out great in the end so thats all that matters right
It is a concern with 0.6mm commercial veneers that too much scraping and sanding will go fairly quickly through to the ground. I usually find that a bit of light scraping and then sanding brings up an acceptable surface which is then ready for a finish.
If you were to do any more veneering, I'd suggest making a veneer shoot as it makes jointing the edges easier. I tried the router method (which works if the mdf edge is guaranteed straight) but I now prefer to use the veneer shoot and a nice long plane...the longer, the better.
The main thing is though, that you got a good result and like we've said many times on the forum, there's lots of ways to go about various tasks - Rob
