AJB Temple":1idemod5 said:I think you are rather hard on yourself. That work looks very professional. I would be proud of it. Adrian
You're right to some extent. Overall I'm really chuffed with it as I've never attempted anything like this before. However, I want to recognise the imperfections so I can improve. The main bit I'm disappointed with is the breadboard ends.
The main issues were as follows:
- I hand flattened the table top and it ended up fractionally thicker at the front than the back, and I didn't realise.
- I cut the tenon for the breadboard end using a dado blade on a table saw (this project is a mix of hand tools and machines) and because of the thickness issue I ended up with a tight tenon at one end a slightly loose one at the other.
- When fitting the breadboard end, it was very tight at one end and in removing if I ham fistedly knocked a corner off. That annoyed me, but I repaired it and most of it was removed anyway when I planed everything to size.
- I made another heavy handed mistake when I put the dowels in the breadboard ends. I draw bored them, but overdid it on a couple of holes. I whacked the dowels in(buoyed with confidence from the previous ones) and they went in at a slight angle and caused a bit of blow out on the back. Fortunately the top is alright. I will just fill/patch up the damage on the back.
- They are a bit gappy. Actually, they looked better before I put the draw bores in!
On the final point, one issue I have (and I have a similar issue with mortise and tenon joints) is fine tuning the shoulders of the tenon. If there's a gap, it usually looks as though it's caused by a shoulder being tight in one place (usually on one side) and there being a gap elsewhere. I guess the problem is either slightly inaccurate marking or cutting, but presumably the only answer once you're at that stage is to relieve the tight shoulder slightly to even things up? I don't have a shoulder plane and have always tried paring it back with a chisel but the results are never very satisfactory (mainly because I don't end up with a flat shoulder. Do I "need" a shoulder plane?! We're only talking about micro adjustments here (it would be a couple of fine shavings along the shoulder) so I find it hard to do with a chisel. Is there another technique I'm missing?
