divein
Thanks for your comment. I was considering a table saw but as I already have the tracksaw and a 40 year old workmate this could be the better option for now as I am 'between' houses.
divein":ppa0995m said:I know this is an old thread but has anyone tried the mft or equivalent with a B&d 625 workmate? I presume that there would be stability issues with the overhang.
JJ1":35flr2wy said:divein":35flr2wy said:I know this is an old thread but has anyone tried the mft or equivalent with a B&d 625 workmate? I presume that there would be stability issues with the overhang.
Only just seen your question and perhaps you've already found your answer, but in case you haven't, I can confirm that the MFT top works perfectly on top of a B & D workmate. The overhang isn't an issue whatsoever and the top takes seconds to secure. I use just two of the Festool screw clamps towards the back of the top. In fact, I find the MFT top so useful I use it all the time on the workmate for pretty much everything.
Benchwayze":3lutaiap said:JJ1":3lutaiap said:divein":3lutaiap said:I know this is an old thread but has anyone tried the mft or equivalent with a B&d 625 workmate? I presume that there would be stability issues with the overhang.
Hi JJ,
How do you make clearance under the top, for the clamps, and any bench dogs, that you use in the bench holes? Do you use two Workmates, and span them with the top?
I am not being critical, but unless you use the dog holes in the MFT top, (Or in one of Stu's replicas!) you might as well just clamp a piece of 18mm MDF to a workmate.
I use two cheap Workmate copies. Despite being somewhat flimsy, in comparison to a proper Workmate, they are no less stable than the MFT itself. So on fine days I work in the yard, without moving the MFT from the shop. (I do make use of bench dogs, which means I don't need the MFT fence and protractor.)
John![]()
