Are these Marple chisels worth £50?
Jorica
23 Jan 2025
Leicester
Hi,
Apologies, this is the second post I'm making about chisels and I don't quite know the etiquette of forums.
I'm looking at some quality second-hand chisels as a beginner. I've seen these on eBay - "vintage 1001 Marples chisels set" for about £50. Some surface rust but it doesnt look too bad. Do these look sufficient? Or am I better saving my £50 for elsewhere?
Cheers!
    421 KB
We're talking wood turning chisels here. The're a bit on the small size, unless you have a mini lathe. but okay for small spindle work. It equates to about £ 8 a tool, which in the great scheme of things doesn't amount to much.
I tend to find "meatier" chisels than this a lot more useful , but then the prices will be far, far, higher.
Hi,
Cheers!
I bought a set of three of this sort from a market stall way back when I first got into turning. Never used them, bought longer and meatier ones instead.
I've been caught out too - buying a parting chisel which turned out to be really tiny!
If they don't tell you the size they are hoping to rip you off.
Ok turning this on its head
Yes I would buy those at price, I started with a set like that and like others I have bought bigger set
However, the flip side of that’s I am doing small fine work so I have gone back to the smaller tools. The only bigger tool used in all these is the roughing gouge to get from square wood to cylinder
    967.6 KB
    1.2 MB
    1.2 MB
    911 KB
    1.1 MB
