powertools
When using a table saw there are a lot of things to to take into account.
No 1 make sure the fence is in line with the blade.
No 2 always use the riving knife.
No 3 always lower the blade to the minimum height to complete the cut.
No 4 always make sure your blade is sharp and is the correct type for the cut you are about to make.
If you have done all of that then you have reduced the chance of having any problem to almost zero.
Having done the above a tennon saw style push stick is the way to go and your other hand can keep the wood against the fence well back from the blade.
