Does the table move of you turn the handle? If no, that’s normal, if yes, not so.
what you are seeing is probably the backlash, it’s essential to getting parts to work together
it is indeed backlash, i just didnt expect sooo much of it :/
ah i see, as long as its nothing i need to complain about its okIt’s a worm drive, anything with a high ratio will exhibit a lot of movement on the input, if the output is small. My AW106 has about the same
Aidan
I've had my p/t for a while now and thought I would share a few more thoughts on it. Overall it has been great, but I did have an issue a few weeks ago which I thought might be worth sharing in case anyone has a similar problem.
The issue was a piece of wood jamming when thicknessing it. I wasn't taking a very big cut, but it really jammed. I got it out (not very easily), but then couldn't get anything to pull through. I called Axminster and they said they would arrange for an engineer to come and have a look. One thing they asked me is whether I had waxed the beds.
I had waxed the beds quite recently because my workshop is cold and rust can be a problem. However, I thought I'd try some microcrystalline wax and lo and behold it started working properly again.
It took a while to get the engineer visit arranged because of the Christmas holidays. I told them it was working but they were happy for the engineer to come anyway as I was also keen for them to have a look at the minor snipe I was getting.
Engineer came today and immediately said that the roller tension was likely to be too high. He thinks they're using stronger springs but not adjusting the settings to compensate. He said that would cause the snipe and also the jamming, because the rollers are putting too much downward pressure. Took him a few minutes to adjust and hopefully I'll now have snipe free results. He ran a piece through which looked good but I'm yet to try it in anger myself.
Top marks for Axminster's service.
Hi Nick,
I've just bought one of these and I'm getting snipe from the thicknesses. I think its down to the tension. Do you know if it was just a case of unscrewing the small nut at the bottom of the spring or is it a little more work?
The short answer is that I don't know for certain because Axminster sent an engineer out and he adjusted it. Unfortunately I didn't see what he did because I wanted to stay out of his way (covid).
The adjustment is the 4 nuts which are in rectangular "windows" in the thicknesser part of the machine. This is one of them:
I think you just need to unwind those a bit to take some pressure off.
The alternative is to give Axminster a call. They should either send someone out to look at it for you, or talk you through the adjustment.
The signs of the pressure being too much on mine were: the first roller kicking the timber up as it grabbed it and then the timber slapping down on the bed, snipe, and (after a bit of use) a jam. It was the jam which prompted me to call Axminster and for them to send someone to adjust it.
Since then, the snipe has pretty much disappeared. I will occasionally notice some very minor snipe but I suspect that's down to the particular pice of timber I'm machining (e.g. perhaps it has a slight bow in it). It's not the norm and is not enough to cause any problems even when it does happen.
I hope you get it sorted.
The other thing I find is that the fence doesn't always stay square to the bed. I've taken to checking it quickly with a square and adjusting it if need be (which is easy enough to do).
Hi Nick,
Thank you. I watched a couple of videos (I think the Woodgrafter) last night and I realised I did not locking down the height adjustment wheel. I will give that a try first to see if it rectifies it.
That didn't help me unfortunately.
What happens when you feed a piece of wood in to the thicknesser? Does it kick the back up and then slap it down? Mine did that before adjusting the roller pressure. Now it just goes in very smoothly.
I can't see any harm in taking a bit of tension off the rollers to see if that helps. It shouldn't be hard to make an equal adjustment on each of the four nuts and assess the effect.
