Robbo3
I posted this in another reply but it's all good basic information.
Most beginners benefit from using a jig to sharpen bowl & spindle gouges. A basic one is fairly easy to make & to use:
- viewtopic.php?t=4443
- viewtopic.php?t=5360
or
Cap'n Eddie Castelin - https://www.youtube.com/watch?v=5i9RDnJHz9g
probably the original - the Ellsworth jig (opens as a PDF file which can be saved to your PC)
- http://www2.woodcraft.com/PDF/77B61.pdf
As well as the gouge holder, using this system with the tool handle resting in the socket of the sliding base & the length suitably adjusted, you can also sharpen any tool that requires a straight across grind, evenly & consistantly eg parting tools, narrow skews, spindle roughing gouges, even bowl gouges.
Lots of good info to help you understand the shape of the tool (bottom of page)
- http://www.peterchild.co.uk/info1/sflute.htm
- bowl-gouge-sharpening-t42517.html
Also,
About 3 years ago I knocked up one of the home made holders for a friend who was too scared to sharpen his gouges. In my haste I got something wrong & it had a pronounced wobble but I used it to give him a demo anyway.
He took it home with the intention of copying it. Instead he used a load of glue to fix the wobble & is still using it today.
The norm is to let the gouge project 2" from the holder, adjust the sliding base to match the bevel already ground (using a marker pen on the bevel helps) then grind gently, using little more than the weight of the tool. The shape of the finished grind is controlled by the operator spending more or less time on particular areas - the nose generally needing less work than the sides.
HTH
or
Also,
HTH
