Anyone know what these are?
Deadeye
21 Aug 2017
Buckinghamshire
Firm plastic (like tupperware, not completely hard), each with a small hole that goes roughly 50% through.
Should I be capping garden canes, modelling DNA, or what??? They were with my Dad's tools.
    1.7 MB
Beads to make an abacus or something..
See original post "each with a small hole that goes roughly 50% through". I am not sure they would slide along the abacus bar like that.
I have seen similar large red ones on brass-encased thermometers used for taking the temperature of concrete but that is unlikely to be correct.
Beads I think. If they are hard likely acrylic (can also get soft silicone as well), half hole type. You can do all sorts with them, bracelets, keyrings etc , apparently......
What on earth is a "half hole" bead? Also, they're huge
When I laid some slabs, they came with 4 of these moulded one into each corner such that they would not lie completely flush with a hard surface.
I winkled them all out and used them in my catapult to dissuade the magpies from destroying the song birds' nests in our hedge.
Yes, I have got a catapult, after all I'm nearly 9 3/4 now...
Yes, some peeps just don't read proper, what, with half holes and all. Aside, not common in a woodworking shop, so Dad must have got them for a special job (like jumbo knitting needles) or just came across them at a junk sale and thought they may be handy??
If they were for cane, tops then the holes are going to be in the region of 10mm in diameter.
Well I can imagine a scenario. Insert item/retailer of choice!
‘I need a couple of <x> for this project making a <y>.Being thrifty, I’ll look around for something about right.
<Hardware emporium> used to have them, but of course there are only 3 on the shelf and I need 4.
Joy! A pack of 50 costs less than the petrol getting to the shop. I’ll get a pack of 1mm too small and a pack of 1mm too big, and make them work.
Job completed, it would be a waste to throw them out. Even though making a <y> is unlikely to be done again, it was a daft idea anyway. They can be filed away neatly just in case.’
For similar reasons, I have a LOT of 12mm spring locking washers….
They really do look like they go on ends of rods of some kind.
In fact, I know where I have some! I have an ancient wire shoe rack, and it has spherical feet, exactly like these except colour (black) and size (1/2" ish)
There you go, colourful feet for shoe racks! I suppose you could use them for some other kind of feet...
Other kind of feet like... wire record racks! Remember those? They also had spherical feet, same design! And, and, and (I'm on a roll now) wire dish racks! Yay, four uses!
