I had another revisit regarding dressing my tires, as I was to find out that there's no such thing
as a good performing bandsaw which actually has a flat profile on the tires.
Having so is a recipe for compressing set, should one try a mere test run (no cutting involved) with the blade tracked as such that the teeth might be approaching the rubber.
More noticeable, is the distinct lack of beam tension in which one will experience with the blade,
and it will walk back without any force whatsoever into the thrust guides.
If one was to try test cutting using a blade
without set, on tires what's
truly flat,
and using the same blade after crowning the tires, they would find they would be actually get through the cut, what couldn't be done before.
Seems there's no telling some folk, that the Italian machines actually do have a crown on the tires,
and I didn't cop the convex profile that my spare Centauro tire I bought from S&S had, and ignorantly assumed they were such.
This is best explained on this Cook's sawmill video snippet...
It's the same thing as what's happening here
But when stretched out as such...(with gap for the tongue underneath)
You can see that there is indeed a profile, a slightly flatter convexity on the rear of the apex,
and slightly more abrupt on the front of the tire.
Apex @17.5mm from the front edge, so there's 1mm in the difference between the centre of the tire and the top of the crown.
A marker instead of a pen would be better, as it scores the rubber a bit.
Since there's no room for error regarding any skewing,
I glued another bit onto the block for easier alignment to the wheel
(on two axis, that is) and as you can see some duct tape was necessary,
as some masking tape is for protecting paint job,
Block aligned on both axis...
The offcut what's bonded onto the original block, had an old mortise cut into,
so was much handier to adjust the feed of the scraper/cutter (old saw plate)
I agree wholeheartedly about not touching the apex, and you want to always see light of the apex,
as the scraper might likely end up sharper on the apex than the rest of the tool, (whats actually doing some scraping), and it only takes a lick to cause themselves a lot more work.
I used a cheap diamond stick for blunting the apex.
Dressing the lower tire doesn't require a blade installed,
But I was to find that on the upper wheel
definitely does, require a suitable blade installed if using a scraping tool under the wheel, and made sure the wheel was indeed parallel with the column.
Sorry don't have a pic, but you'll have to imagine the blade installed.
One possible caveat here, is my wheels have the faces dressed to about 0.2mm discrepancy.....
