I'm installing a pair of electric gate rams, but I have the silliest of problems. I need to drill 6 holes of 12mm through a 200mm gate post for the supporting brackets. But I need to do it accurately.
Normally, if I need a hole drilling at perfect 90 degrees to the face, I'd use my drill press. But the gate post is already in the ground, so that isn't an option.
I can drill it approximately right by eye, but this needs to be precise - on the inside of the post, it needs to match the bracket holes. The outside of the post is visible, and I'd prefer symmetrical rather than 'random' holes.
I've seen the use of a block as a guide - drilled on the drill press - but I'm concerned there's still plenty of room for drift.
Beyond making the drill block deeper, any ideas how I can improve my accuracy please?
