Retire2004
- Joined
- 6 Feb 2008
- Messages
- 87
- Reaction score
- 2
Accorging to your latest post: the cut is through one plane only(so no binding of the TS blade, yes?) I would do a on a TS with a taper cutting jig to control the angle. Clamp the tube to an "L" shaped jig and pass through using the taper jig. You will be left with a whole cylinder which has a slot through ehich I assume is what you want??? SIMPLES
