RogerS
Thanks, E.
I'd better not start on Matki !
Yes. And the hot water system is also pressurised at 3 Bar as that's the pump rating.nolly47":25hrokl9 said:Hi Roger
I assume that the cold-water pump is flow and pressure operated so cold-water pipework is always at 1 bar even if nothing is turned on
Sadly no. Should have put one in.nolly47":25hrokl9 said:You don’t have a secondary return back to the hot water cylinder, do you?
I see where you're coming from but no.nolly47":25hrokl9 said:When the pumps was running after the shower was shut off did you check the overflows from the loft and break tanks?
Still waiting for the parts to arrive from Hans Grohe.nolly47":25hrokl9 said:With the on suite isolated now, is the hot water and hot water pump working with no problems?
Steve
